Getting ready to do an exhaust swap (LS to R) - What Bolts/Tools should I get?
Are there any bolts I am going to have to replace when I start doing my exhaust swap?
Going from a 99 LS stock cat back to a 01 R cat back. Are there any special tools I should get in order to get the original bolts off? I think some people have had trouble with "melted" bolts...
Any help would be appreciated.
//Alex
//Alex
It just depends if you snap or strip any of the bolts. No need for special tools.. I did it with normal hand tools and ratchet set. Get some WD 40 tho.
[Modified by BSQ, 2:08 AM 10/16/2002]
Thanks guys - Bret, where do you keep getting all those diagrams?
do you have a higher resolution/larger version of that one?
Anyone else run into any problems with any bolts or anything?
//Alex
do you have a higher resolution/larger version of that one?Anyone else run into any problems with any bolts or anything?
//Alex
aleeterninja
Apr 25, 2015 09:52 AM
