d16z6/p29 pistons -- rough Idle and CEL for fuel supply
Old Aug 3, 2012 | 11:21 PM
phrenzy's Avatar
Default d16z6/p29 pistons -- rough Idle and CEL for fuel supply
I have a D16z6 with p29 high comp pistions, getting rough Idle and CEL for fuel supply.
I replaced the 2 exhaust valves on cylinder 3 with non-oem valves, and my compression on cylinder 1-2-4 is 9:1 and 3 is 8:1, I know its not a big difference, but could this cause a little of my problem? and also, I think I should buy at least a chipped ECU, what do you guys think? That could fix my problem also.
Sorry, No replys on my other help post so I remade thread but cut straight to the point.
Old Aug 4, 2012 | 05:56 AM
nealnanoHX's Avatar
Default Re: p29 d16z6 Questions
Uneven compression will cause a rough idle due to the cylinders being uneven.
Ronaldo9
Oct 15, 2006 08:23 PM
Firefoxracer
Jun 16, 2005 08:04 AM
