Timing belt replacement
Old Aug 3, 2012 | 05:39 PM
56belair's Avatar
Default Timing belt replacement
I need to replace my timing belt on my 2002 Honda Accord. Can someone suggest other things to replace while I'm down there? Water pump....
Can someone suggest the tools needed?
I found this good youtube video as well
Paul
Parker, CO
2.3 Liter Accord
http://www.youtube.com/watch?v=KtJQvZ8UcAQ
Old Aug 4, 2012 | 08:51 AM
Slothy's Avatar
Default Re: Timing belt replacement
You will also change the balance belt (little belt that routes horizontal under the timing cover). Some replace the water pump while you're in there, but it's not very often they fail.
Chances are, you'll need the 50mm crank lock tool to break the crank bolt loose, Ive rarley got them off with 150psi & 1/2" impact (northern climate rust). Total job usually is 1.5 - 2 hours.
whiteboy-dc4
Feb 3, 2010 11:52 AM
supracrx
Feb 17, 2008 09:06 AM
shepworldwide
Acura TL, RL & ZDX
Aug 15, 2006 07:37 AM
soaggydogg
Oct 31, 2005 04:48 AM
TERRA
Jan 23, 2002 08:57 AM
