hot and cold heater control knob
Old Aug 2, 2012 | 10:59 PM
navcc's Avatar
Default hot and cold heater control ****
Hi, Fidgiegirl. you need to pull the **** towards you, it should slide off, if not then you need to use the screw driver to carefully slide off the ****. You will find that the **** is cracked from inside. The best way to repair it is by using super glue in the crack and compress the crack until it dries,and then the **** should be ok to fit back on. I hope this info will be a help to resolve it.
marcs1337
Aug 15, 2009 05:19 PM
johnnyangel58
Sep 1, 2007 04:49 PM
20strong
Honda Civic (2006 - 2015)
12
May 22, 2007 05:48 PM
gr8snd
Feb 27, 2007 04:23 PM
andrewasf77
Nov 10, 2002 11:50 AM
