FS: green 4-dr 98 GSR, likely for parts, San Jose
Like with an old girlfriend, I've reached the point where I am done with my Integra. If this were Forza 4, the car condition would be yellow all-around. So I'd think anybody wanting to buy this would likely want to part out the car.
I am not interested in parting out this car; I want this car out of my life. (Although I could sell the sets of wheels individually.)
Make offer.
The details:
- green 4-door 98 GSR, located in San Jose
- 172k
- about 15 track days, including 2 days at Road America!
- last engine/supercharger rebuild at 138k
- hit tire wall at Infineon Sears Point, which pushed front bumper to the left one inch; frame, bumper, hood straightened out, bumper bondo'd; rear right bumper took secondary hit, pulled out indentation and painted
- oil pump failed while on track at Laguna Seca at 161k; engine still makes power, but keep blowing out oil pan gasket (likely due to blow-by past rings) - oil drips onto header collector
- ITR tranny -- LSD starting to fail: car has veered left at highway speeds on uneven roads
- spare stock GSR tranny, pulled off at 108k
- P/S, A/C, cruise control all removed
- carbon fiber hood, spray-painted green, dinged in the back corners
- Koyo aluminum radiator
- ebay SRI, with K&N DryFlow filter
- 10psi on supercharger, with CTR crank pulley
- Labonte stage 2 water/methanol kit (with M2 or M3 nozzle, I forget) -- turns on at 2psi, full on at 5psi
- ITR cams, ITR springs
- forged pistons, 9.0:1 compression -- 232hp, conservatively tuned
- Kamikaze header -- collector was cracked and welded -- flange between collector and cat is damaged, with some exhaust leakage
- Apexi WS exhaust
- Koni yellow sport shocks, Eibach springs, lowered 0.75"
- OmniPower adjustable front UCA, recently replaced balljoints
- Neuspeed 4-point strut bar
- adjustable rear toe links
- ASR subframe bar
- Unorthodox (?) 22mm (?) rear sway bar - whatever bigger than stock
- 5Zigen FC01R 16" wheels, with Bridgestone RE10 205/45/16, about 1k miles
- two sets of 15" track wheels: black Drag DR 21 with old set of 205/50/15 Toyo RA1, bronze Konig Network with newish set of 205/50/15 Nitto NT01 (or could be the other way around)
- random maintenance/stock parts, like brake rotors, BKR-7E copper plugs, original springs, original exhaust
Make offer.
The details:
- 172k
- Apexi WS exhaust
- ASR subframe bar
PM'd replied.
Other stuff on the car I forgot:
- Skunk2 short shifter and ****
- boost meter at cruise control switch location
- Hondata s100 ECU
- Hondata s100 ECU
RubenGSR95
Jul 9, 2009 11:45 AM
