80A fuse blowing
Old Aug 2, 2012 | 10:49 AM
tjman982002's Avatar
Default 80A fuse blowing
I have a 2000 Civic LX. I have been replacing the bumper cover, bumper reinforcement and headlights from a previous owner.
I removed the battery to let it charge. When I went to place the battery back in the car, it blew the 80A fuse under the hood. It happens each time I try to connect the negative cable to battery. I have checked the ground from the trans to the body and from the battery to the body. I have cleaned both, but I'm at a loss as to what to do now.
Any ideas?
Could a bad battery but the problem? I've never had this issue before on any vehicle.
Old Aug 2, 2012 | 11:23 AM
Former User's Avatar
Default Re: 80A fuse blowing
Are you installing the battery backwards --> + to -?
Old Aug 2, 2012 | 12:51 PM
no...not according to the terminal posts on the battery and the clamps on the cables. I may go buy a new battery to see if that was the issue. I know some people state it's the alternator, but that shouldn't be it, since I don't even get to make it that far in the ignition process.
I can't even hook it up w/o blowing the fuse. It's weird that it just started happening. I've replaced the battery before and never had this issue.
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
RemoveGiantWingOnYourCar
Nov 3, 2006 08:04 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
barefootbilly
14
May 25, 2004 06:32 AM
