Short Ram VS Cold Air Intakes, what is best?
Old Aug 2, 2012 | 09:38 AM
RITLINBOY-91.SI's Avatar
Icon2 Short Ram VS Cold Air Intakes, what is best?
Hey HT I have a 2001 GSR with a POS intake on it.
There are so many different types on intake on the market which one is the best or decent enough to get. Is there any problem with an Aluminum pipe and no namer filter? Lastly does the color of an intake matter between red, black, polished, so on. If I got a black cold air intake would the black one generate more heat than a polish? Thanks guys.
Old Aug 3, 2012 | 01:31 AM
Hyper16-Johnny's Avatar
Default Re: Short Ram VS Cold Air Intakes, what is best?
In all honesty, with a stock motor don't even worry about such nonsense. On a built and tuned allmotor setup than a longer intake pipe is more ideal.
Old Aug 3, 2012 | 07:09 AM
ej6_b18c's Avatar
short ram. if you want to hydro lock your motor cuz its cool to have an intake out the fender, and color is just preference. i have a carbonfiber password jdm intake on mine (only cuz i got it like that) a short ram will be an improvement over stock and it wi.l clean upp the bay some. you need o tell us what motor you have and what your goals are first though
Old Aug 16, 2012 | 08:16 AM
LownSlowEkd16's Avatar
You should go with AEM or K&N, those and other brands give you the capability to switch between short ram and cold air by removing or reinstalling the tube that elongates the tubing for cold air. As for performance, you'll get the same, if not very close to same HP gain.
Old Aug 16, 2012 | 09:05 AM
kickadog55's Avatar
longer is better, you dont have to worry about hydrolocking your motor. for one you would have to drive through a Sh** ton of water, and two they make a special valve you put on the intake to prevent hydrolocking your motor in rainy places. i live in seattle. i have always had cold air intakes never had a problem
Old Aug 16, 2012 | 09:50 AM
Magik8252's Avatar
3in short ram VL intake good to go all day.
Old Aug 16, 2012 | 10:42 AM
MonkeyMagic's Avatar
in all reality, you're better off with the stock stuff.. just remove the resonator assemblies and leave the box, filter and arm.
if you want bling, short ram. ebay pipe and a good filter. not k&n.
Old Aug 16, 2012 | 11:45 AM
fuel..'s Avatar
as monkey says for light tuning simple remove the resonator assemblies and leave the box, filter and arm it work fine ....if you want to work better is high end then short pipe (this is the theory of itb) if you want mild gain then long pipe with a filter ....
as for all motors and drag you can run 2,5 -3 inch pipe straight to the headlight
RITLINBOY-91.SI
21
Aug 3, 2012 09:39 PM
tapiasradiator05
Honda Civic (2006 - 2015)
79
Aug 11, 2009 06:34 AM
Matt53
Nov 12, 2006 07:02 PM
katb16vo
Mar 18, 2004 06:55 PM
BearAccordEX
Nov 12, 2001 05:02 PM
