200K Miles
So the teg reached its mark. more like 215k. can anyone refer me to a mechanic in the SoCal area? so i have a list here. let me know if there is anything im missing. or if any of these necessary.
timing belt
water pump
thermostat
Alt belt
power steer belt
head gasket
valve and spring adjustment
spark plugs
spark wires
dist cap and rotor
radiator hoses
brake fluid
steering fluid
cam seals
timing belt
water pump
thermostat
Alt belt
power steer belt
head gasket
spark plugs
spark wires
dist cap and rotor
radiator hoses
brake fluid
steering fluid
cam seals
timing belt
water pump
thermostat
Alt belt
power steer belt
head gasket
spark plugs
spark wires
dist cap and rotor
radiator hoses
brake fluid
steering fluid
cam seals
timing belt
water pump
thermostat
Alt belt
power steer belt
head gasket
spark plugs
spark wires
dist cap and rotor
radiator hoses
brake fluid
steering fluid
cam seals
you should consider checking the spark color and the ouput #'s of the coil and ignitor
-radiator fluid
-valve cover gasket
-pcv valve
-an oil change after running the car on the new timing belt. Its to help remove contaminants that could have fell in when the valve cover is off.
i highly suggest oem parts for this job
-radiator fluid
-valve cover gasket
-pcv valve
supergtp1
Jun 2, 2014 10:22 PM
