Del Sol Parts - JDM OEM EDM USDM
PM or text 615-818-3672 (fast response) for offers guys!
Fuse Box (under hood)
OEM JDM Lower Fogs w/rubber boots and pigtails
OEM JDM Aux Lights
OEM JDM Front rad support
OEM Driver FenderSOLD
JDM 1 Piece Headlights (Black)
***OEM Custom Yellow 96-97 Fogs***
OEM stock intake resonator box
OEM Radiator Fans
OEM Condenser
9003 Bixenon 3000k (deep yellow) HID bulb set
OEM mudflap set
OEM Rear Lower Control Arms - w/sway bar hole
OEM Spring set
Misc. Brackets
JDM Map Light Block off plates
Center console block off plate
Intake rubber connectors - Yellow + Blue
Lugnuts
2x 9003 Headlight bulbs
Ebay Power antenna mast
Random wires + Fuse
Random PCV valves
Switch sets for above instrument cluster
Drain Plug 17mm
JDM maplights and rods BOXES AND BAGS ONLY
OEM radiator w/auto trans cooler (x2)
Energy Suspension Front Sway Bar End link Set
Interior rear speaker grill covers SOLD
OEM shift boot
S2000 Seat Pans
Throttle body - stock
Engine Damper kit (Godspeed brand) SOLD
Throw out bearing - SOLD
Shifter (I think it is a short shifter, but cant be sure)
Distributor
Shift dust boot
Headlight bulb dust shields x3
Fuel pump
VSS - SOLD
vtec solenoid - SOLD
Fuel Rail
EMPTY BAGS AND BOXES ONLY
OEM JDM Aux Lights
OEM Radiator Fans
OEM Condenser
OEM mudflap set
OEM Spring set
Misc. Brackets
Lugnuts
Random wires + Fuse
Random PCV valves
Drain Plug 17mm
OEM shift boot
S2000 Seat Pans
Distributor
Shift dust boot
Fuel pump
VSS - SOLD
Fuel Rail
