New Numbers on the Stock Sleeve B16A Setup: 515whp on 93 Octane
Old Aug 1, 2012 | 06:13 AM
tscook3's Avatar
Default New Numbers on the Stock Sleeve B16A Setup: 515whp on 93 Octane
Just wanted to share the results of the new pump gas numbers with my B16A setup and give a shout out to Innovative Motorworks for the help / tune. Here is the basic setup:
Stock Sleeve B16A
Synapse V-Band Top Mount
Precision 6266
ID 1000s / Walbro 255
Victor X IM
Skunk2 Pro-1 Cams
93 Octane on 20lbs:
And here are a few of the car:
Figured some of you would be interested in some decent 1.6, stock sleeve / pump gas numbers. Still a couple goals left to hit with the car. Thanks to Innovative for the cam install + awesome tunes as always!
Old Aug 1, 2012 | 06:18 AM
ls_on_boost's Avatar
Default Re: New Numbers on the Stock Sleeve B16A Setup: 515whp on 93 Octane
Nice
Old Aug 1, 2012 | 06:41 AM
EsotericImage's Avatar
Retired Moderator
nice car!
great numbers!
Old Aug 1, 2012 | 06:47 AM
rich7777's Avatar
You can't argue with this B16 lol
Old Aug 1, 2012 | 06:49 AM
dj211855's Avatar
diggin it!
Old Aug 1, 2012 | 06:56 AM
93turbo16's Avatar
This is definitely the highest HP stock sleeve B16 we have had through here on pump gas, that is for sure!
This car is meticulously put together, we couldn't have ask for a better prepared car!
Here is the video that one of your friend's took while it was on the dyno as well!
http://youtu.be/prnZB94sDoI?hd=1
Old Aug 1, 2012 | 12:08 PM
sleepencivic's Avatar
specs on the turbo?
Old Aug 1, 2012 | 01:21 PM
yzracer323's Avatar
nice, hope is stays together for you!
Old Aug 1, 2012 | 01:56 PM
DDTECH's Avatar
Great John and IWM. Looks sweet!
Old Aug 1, 2012 | 02:25 PM
crxking1's Avatar
Nice
Old Aug 1, 2012 | 02:49 PM
Mike Lowwryyy's Avatar
Stock sleeve or stock block? What piston rod combo you running?
So how does it idle and whats the driveability like?
What valvetrain you running also?
Nonetheless. Very very nice build
Old Aug 1, 2012 | 06:24 PM
tscook3's Avatar
Precision 6266SP w/ v-band inlet .82 housing.
Stock sleeve. JE Pistons / Eagle rods. Idle is a tad above 1k rpm. Driveability is great. Crower valvetrain.
Thanks, guys. And thanks, John. Appreciate the kind words! If anyone on here is looking for a tuner around south-central PA, def. look into Innovative Motorworks. John @ J-K-Tuning (93turbo16) has tuned this car three times now and he is great @ what he does and always willing to go out of his way to help you out.
Old Aug 1, 2012 | 08:04 PM
DC2Mex's Avatar
Very very nicely put together.
Hoping to put 450whp on a built gsr with stock cams with a PTE 5858 on 91
Old Aug 1, 2012 | 08:41 PM
rico892002's Avatar
good **** toby..john whats the timing set on this thing..very good numbers
Old Aug 3, 2012 | 04:23 AM
tscook3's Avatar
Thanks guys
Old Aug 3, 2012 | 07:18 AM
thid92's Avatar
can I haz?
any tapping noise from those pistons at start up? I have the same brand pistons and hear some piston slap when I first start it up.
Old Aug 3, 2012 | 12:10 PM
that depends on the PTW clearance
Old Aug 3, 2012 | 01:05 PM
Janet@bisimoto's Avatar
Nice!
tscook3
May 28, 2014 06:19 PM
Dave_Dc2
Oct 11, 2008 07:00 PM
Dave_yd
May 16, 2008 02:29 PM
PrecisionH23a
Feb 24, 2006 06:27 PM
B16Anees
27
Jul 29, 2003 09:25 AM
