1984 CB700SC Unknown Part Help
Old Jul 31, 2012 | 09:02 PM
berinti's Avatar
Default 1984 CB700SC Unknown Part Help
I have an 1984 Honda Nighthawk S (CB700SC) and I recently did an oil change with a new torque wrench and something went wrong. While I have changed the oil in the bike many times, it was either that I set the torque wrench up incorrectly, or I'm just an idiot, but it started to leak oil as I tightened it. I immediately loosened the plug completely, and out with the drain plug came what appears to be an aluminum washer. I looked through the manual but couldn't figure out what this part was, and looking at THIS diagram, I'm guessing it is the part labeled 20. Would anyone be able to confirm this? I've attached images of the piece.
Thanks so much in advance!
Old Aug 2, 2012 | 12:54 PM
blackaneseman's Avatar
Default Re: 1984 CB700SC Unknown Part Help
It does look like the crush washer that is used with the drain plug. 50cents should get you a new one at the dealership. They should be replaced every oil change.
Old Aug 2, 2012 | 01:28 PM
KooK's Avatar
Mustang Sally
That sir, is one used and abused drain bolt washer.
Local auto parts store like ^^ said. 12mm drain plug washer and it'll cost you a whole dollar plus sales tax!
Old Aug 6, 2012 | 09:42 AM
berinti's Avatar
Thanks so much for the responses. I went ahead and ordered one online, and should be up an running soon.
Thanks,
Cliff Berinti
Old Aug 6, 2012 | 10:48 AM
KooK's Avatar
Mustang Sally
Well what's weird to me is the shape it's taken on... The drain bolt still threads into the block, right?
Old Aug 13, 2012 | 05:33 AM
berinti's Avatar
Yes, it turns out it isn't the washer. The drain plug still threads into the block. I went up to a shop and we ordered what was their best guess on what the part was. I'll update once I get it if it works out.
Thanks,
Cliff
Old Aug 14, 2012 | 06:04 AM
Kiwibird83's Avatar
Reigning GDD Queen
Post up them bike pics son.
Old Aug 14, 2012 | 09:09 AM
KooK's Avatar
Mustang Sally
What did you guys think it was?
Old Aug 25, 2012 | 09:18 AM
berinti's Avatar
So the bike shop ordered me a rubber O-ring. The convex aluminum ring is the piece I'm trying to replace, the washer at the top is the drain plug washer, and then the O-ring is on the right. I could break out the drain plug if that would give more context of how this piece came out of the block. Any thoughts guys?
Old Aug 25, 2012 | 09:39 AM
RVF400's Avatar
I am guessing your new TQ wrench is the kind that clicks when you hit the specified TQ. Set the TQ wrench to 10-20 ft lbs and try it on something like a lug nut on a car. Does the wrench work right?
If your shop can't tell the difference between rubber and aluminum or between black and silver - FIND ANOTHER SHOP.
mark@silbernage
Feb 24, 2011 07:48 PM
DannyDeuce
Feb 17, 2006 01:21 PM
Rayog21
Oct 3, 2004 02:04 PM
ee-gsr
Jul 13, 2002 01:48 PM
