Civic 92-95 * Civic 96-00 * Integra 94-01 *Del Sol 93-97 * Portland 2 Seattle 8-4-12
Old Jul 31, 2012 | 01:24 PM
DB8 RHD's Avatar
Default Civic 92-95 * Civic 96-00 * Integra 94-01 *Del Sol 93-97 * Portland 2 Seattle 8-4-12
Integra
94-01 Acura Intgegra Hood **COLOR CODE NH-538M** (few imperfections) - 100$
94-01 Acura Intgegra Passenger Fender **COLOR CODE NH-538M** (few imperfections) - 80$
94-97 Acura Intgegra Driver Side head light (new aftermarket - OEM Style) - 100$
94-01 Windshield Wiper Motor - 20$
94-01 B Series Driver Side motor Mount (Chassis to Engine)- 20$
94-01 Column Cover (black) - 10$
94-01 2DR Windshield Side Molding (pair - both sides) - 20$
96-01 Distributor (removed from 98 LS comes w/ plug wires) - 80$
94-01 2DR Trophy Panel - 40$
94-01 Subframe (control arms, brace, sway bar, steering rack w/ all lines & pump) - 100$
94-01 Passenger air bag - tan - 50$
94-01 2DR 1/4 Panel Inside Plastics - 40$
94-01 Acura 14" Hub Caps (scratches etc) - 20$
00-01 Steering column (w/ stalks & black box ignition w/ match key & GSR ecu) - 600$
94-01 Driver air bag - tan - 50$
94-01 Automatic Starter
94-01 Passenger air bag - black (has some rough spots on cover) - 20$
94-01 Front cut - Strut Towers forward w/ core support all oem - 150$
94-01 Stock Suspension (springs / struts) - 100$
94-01 4DR Mud Flaps - 50$
96-99 Auto Engine Harness - 100$
94-01 Auto Driver Side Axle - 20$
94-01 Auto Passenger Side Axle - 20$
94-01 5spd Transmission Vibration Mount (Transmission & Frame) - 40$
94-01 A/C compressor - 40$
94-01 2dr Tail Light Gaskets - 40$
94-01 2DR Window Regulators w/ Motors (each - Per Side) - 20$
94-01 T Bracket Motor Mount (Auto) - 40$
94-01 Passenger Side Motor Mount (Upper - Auto) - 20$
94-01 Driver Side (block) A/C Pump / Vibration Mount - 30$
94-01 A/C Condenser - 60$
94-01 Cluster Bezel - 5$
94-01 GSR Cluster - 50$
94-97 2DR Tail Lights - 40$
94-01 Automatic LS Cluster - 40$
94-01 Side Skirts (2dr) - 40$
94-01 2dr Stock Spoiler (silver *Not Type R*)- 40$
94-01 Factory Intake Arm w/ filter box - 40$
(2) 94-01 Automatic Half Shaft (ready to bolt on) - 50$
Honda Civic 1996-2000
D16Y8 Oil Pan - 60$
D16Y8 Exhaust Manifold - 30$
96-98 Honda civic grill (white w/ Gold emblem) - 30$
96-00 A/C Condenser (w/ fan) - 60$
96-00 Dark Grey Inner Door Handles - 20$
96-98 Civic ex sub frame w/ control arms & steering rack - 100$
1997 Civic HX ECU 5spd (p2n-a22) - 40$
96-00 Civic Light Gray Drivers Air Bag - 40$
96-00 Civic Center Console (Dark Grey - Rear Section - Cloth Armrest Lid) - 30$
96-00 Civic Light Gray Passenger Air Bag - 40$
96-00 Civic Knock Sensor (Pulled From D16Y8) - 60$
96-98 Civic D16Y7 5spd engine harness - 100$
99-00 Honda Civic (Heater Core / evaporator / blower) - $60
96-00 Civic D Series A/C Compressor - 30$
99-00 Civic Passenger side Headlight (oem) - 40$
96-00 Civic Passenger (EX - 2dr) Light Grey Door Panel - 30$
96-00 Civic HX Engine Harness (removed from a 2000 5spd - should fit 96-00 sense hx models are All obd2a) - 140$
96-00 Civic Exhaust B pipe (2dr)- 50$
96-00 Civic Dark Grey Front Seats (pair) (1 small seam split drivers seat bottom) - 80$
96-00 civic D16Y8 Starter 5spd - 20$
96-00 civic Windshield Washer Bottles - 10$
96-98 Civic Head Lights (each) - 40$
96-00 Civic OEM Sail Panel Tweeters - 40$
96-00 Civic Cluster Bezel - 10$
1992-1995 Honda Civic
92-95 Civic Rear Lower Control Arms (each) - 30$
92-95 Civic hatchback cargo cover (black) - 125$
92-95 Climate Control - 30$
92-95 Dash Face (climate control, radio mount in it) - 30$
92-95 Civic Stock suspension (springs / struts) - 100$
92-95 Civic Fuel Pump Assemble (complete)- 20$
92-95 Civic Power Steering Resivor - 10$
92-95 Civic Grey Drivers Air bag - 40$
92-95 Civic 4dr Power Window Regulators (all 4 available) - 20$ (each)
92-95 Civic Black Drivers Air bag - 40$
92-95 Engine Harness D15B2 - 100$
92-95 5spd B Series Transmission Vibration Mount (Transmission & Frame) - 40$
92-95 Civic Black Passenger Air bag - 40$
92-95 Civic B Series Driver Side motor Mount - 20$
(2)- 92-95 civic Black Steering Wheel - 10$
(3) - 92-95 Civic Coupe side skirts (pair) - 20$
92-95 civic 4dr sedan side skirts (pair) - 20$
92-95 Civic Manual Steering Rack - 40$
92-95 civic (coupe only) Whale Tail Style wing - 40$
93-97 Del Sol
Cargo Bins - 100$
Passenger air bag - 100$
Driver Side Fender (blue - Clean paint) - 160$
Side Skirts - 80$
Passenger Door Shell (no glass no door panels No Handle No Regulator - Blue - Clean Paint) - 120$
Front Bumper (brand new) - 50$
Driver Side Quarter Panel - 160$
Core Support / Front Cut (firewall forward) - 180$
Front Complete Si(B16) Hubs (OEM Big Brakes) - 120$
Aux Lights / Hazard Buttons (pair) - 20$
Drivers Air Bag (black)- 50$
Targa Top holder - 80$
Head Lights - 90$ (each)
Drivers Door Glass - 50$
Rear Speaker Covers - 50$
Side Marker (Drivers only - Next to headlight) - 10$
Glass:
93-97 del sol drivers door glass - 50$
93-97 del sol windsheild - 50$
92-95 civic coupe passenger 1/4 panel glass (both sides available) - 40$
92-95 civic (4dr - sedan) Back glass - 40$
92-95 civic (4dr - sedan) I have all 4 door glass - 20$ (each)
92-95 3dr Civic Rear Hatch glass - 40$
94-01 2dr Integra passenger door glass - 40$
96-00 civic coupe Passenger 1/4 panel glass - 40$
96-00 civic coupe Drivers 1/4 panel glass - 40$
96-00 civic coupe Rear glass - 40$
MISC
2 - OBD2 D Series Alternator - 20$
1 - Civic Half Size Radiators w/ fan & overflow (5spd) - 100$
4 - 92-00 Civic D Series Shift Linkage (1 set has a short shifter) - 30$
1 - OBD2 B Series Alternator - 20$
92-00 Civic Rear Drum Assemblies (rear to bolt on - NO LCA) - 40$ ( Per Side
Sony Xplode 6x9 #-v6955g - 40$
Integra DC GSR Rear Sway bar (w/ Endlinks and Brackets) - Fits 92-00 Civic - $40
Factory Jack Kits - 20$
Factory Doughnut Spares (4) 13" - (1) 15" - 20$
Transmissions:
Honda Civic LX (P4A) (5spd) (w/ 156k) (Would shift into gears > but wouldn't move - good for case or rebuild-able core)- 50$
Acura Integra (1998) Automatic Transmission (S4XA-3340051) - 300$
Cars - Located Gresham, OR
94 Acura Integra LS Automatic Clean Title 2dr Green / Black Interior, AUTO w/ 150k-ish, kinda rough looking but runner driver - 1500$
96 Civic EX Coupe Shell, 5spd, Clean title, green, light grey interior, needs swap and new core support put on (comes with) a/c still charged - 1100$
95 White CX Hatch 5spd Shell, Clean Title, Was a drag car, so pretty stripped (no interior, minimal wiring), gonna need a lot to get back on the street or minimal work to run at the track again. - 500$
95 Civic Hatch VX (bone stock) Clean Title - Red / Black Interior, Runs Drives Great, Small Dent in Roof, 180k, new timing belt, water pump, clutch - 3500$
I do NOT live in Seattle, I will be in the area on 8/4/12, I can meet you anywhere off I5 North From Portland, or I can meet at Tacoma mall (12-2pm) or South Center Mall (3-5pm), or deliver for fuel charge
971-212-8011 --- Text / Call *** Discount purchasing 3+ Items
b0osted iinteg
Mar 5, 2012 12:46 AM
msmotorsports
Aug 1, 2008 09:12 AM
kelviiv
Jan 19, 2008 02:05 PM
itsm3paul
Northwest (Sales)
May 24, 2006 05:02 PM
