b18 swaped crx
thinking of buying a 91 crx with a b18a1 swap and Buddy club adjustable cam gears
Place racin motor mounts
Adustable fuel pressure regulator
Cold air intake
Front strut bar
Skunk 2 pro series 5 struts and adjustable coilovers
Slotted and drilled rotors
Blox lower control arms
Spoon sports steering wheel
for 1200-1600 bucks only down fall i see in it is no trans...
if i buy it what trans would i need to put in it a factory crx or and ls integra? thanks
Cold air intake
Front strut bar
Any cable B-series trans will bolt right in. You CAN NOT bolt a D-series trans to a B-series block. I would try and pick up a YS1, hopefully one out of a 92-93 GSR for better gearing. Plus those cases can accept a higher amount of different gear sets but any 1990-1993 integra transmission will bolt in.
Other than that with a little work that could be a fairly clean little car.
From the pictures I can see it isn't the cleanest of work. There are multiple wire and cable anchor bolts missing. It looks pretty sloppy actually just from the limited pictures. I would buy it but would be expecting to fix someone else' mistakes.
