94 teg cluster help
i have a 94 teg and today i noticed that when i turn on the ignition switch the rpm gauge n speed gauge moves up n the gas pump wasnt turning on.
So i went ahead n check the fuse box sure enough there was 3 blown fuses, i replaced them,now the gas pump turns on, but i still have the problem with the gauges moving up when i turn on the ignition switch
any help would be appreciated
