air horn mounting location question
my dad just gave me a set of airhorns to replace the stock one in my car, theyre hellas if it matters, now the wiring part is easy but how should i mount them? its an eg civic sedan btw, would behind the bumper be ok if they were angled down or should i avoid that area all together, and mount them near the firewall like i was originally thinking?
if there is enough room in between the bumper and the radiator, i would mount them there, on the firewall you will loose more volume, and it will be annoying to the occupants of your car then the stupid driver that just pulled out in front of you, just a thought
good luck!
good luck!
good luck!
good luck!
theyre really stinkin lound as is, the only thing im concerned about in the bumper is water getting into them and potentially messing them up, when i get an alarm i might hook them into that too instead of adding a siren...but we shall see what happens, im finishing the wiring now then im gonna install them in the am
VTECAcuraGSR
Apr 5, 2005 04:48 AM
JDMTurboCivic11
Feb 9, 2005 06:29 AM
