f22a1 to h22a4 swap
Old Jul 27, 2012 | 06:40 PM
bizzle2288's Avatar
Icon2 f22a1 to h22a4 swap
looking for any info on anf22a1 to an h22a4 swap into a 90 accord lx completely rebuilding the h22a4 , what's interchangeable ( harness, ecu, transmission, crankshaft etc.) any info regarding this would be greatly appreciated
Old Jul 27, 2012 | 08:00 PM
bizzle2288's Avatar
Default Re: f22a1 to h22a4 swap
Old Jul 27, 2012 | 08:06 PM
Julio@Bisimoto's Avatar
There are many similarities between F and H-series engines however when swapping over to an H22 I would recommend investing on an H22 transmission for shorter gearing as well available LSD option from the factory if you get lucky and find one. Your F22 harness can be used with some modification and adding a few wire for such items such as vtec, knock and so on. You will also need an H22 intake manifold and H22 header being that the F22 is not compatible.
If your plans are to build the H22 engine I would suggest investing on an engine management system to replace your ecu allowing you to tune and optimize fuel and ignition maps. For my own projects I have always invested on a AEM EMS Series 2 which is a stand alone system that will replace your factory ecu entirely giving your total control over all your engine parameters as well many other beneficial features for your setup such as launch control, datalogging and even close loop operation with an AEM UEGO Controller allowing for auto correction of your fuel map while you are driving/racing!
Old Jul 30, 2012 | 06:43 PM
soud's Avatar
Default i need help in swapping
i swap my f22 a/t with h22 manual ta. , i change the ECU , im using (p13) ecu , but the poblem is that my maximum rpm is 5200 ,
h22 with 5200 rpm ?!!!!!
how can i solve that problem ?!!!!!
please help
the h22 maximum rpm should be 8200, isnt it ?
and how i can reach that rpm ?
Old Jul 31, 2012 | 01:06 PM
GhostAccord's Avatar
Is your check engine light on? If not you should still probably check the ECU for any stored codes.
Did you use an OBD1 92-95 H22A1 engine and an OBD1 P13 ECU?
Old Jul 31, 2012 | 04:18 PM
soud's Avatar
yes i did , but the problem is even if i change my ECU with a chipped one (8500 rpm ) , my car will still have the same rpm (5200rpm )
Old Jul 31, 2012 | 04:21 PM
soud's Avatar
everybody telling me that i must change the engine harness to have a higher rpm ; is thats true ?!!
Old Jul 31, 2012 | 06:16 PM
bizzle2288's Avatar
http://www.cb7tuner.com/vbb/showthread.php?t=5423 i got some info from here a bit of it is helpful, and if your running your OBD-1 harness did you run your V-TEC wires?
Old Jul 31, 2012 | 10:29 PM
jdmcertified909's Avatar
your either in limp mode or have a big air leak soud. i had a 94 accord with a leaking intake manifold gasket and it would give me 4k 5k rev limit with no check engine light.
Old Aug 1, 2012 | 12:07 AM
Just wondering if you ever retrieve the code(s) from the ECU to see what the CEL was on for? It could point you toward the issue you are having.
slammed_92_accord
Jan 7, 2006 08:29 PM
rkn527
Mar 26, 2003 06:04 PM
