Factory Steering Bump Issues
Old Jul 27, 2012 | 04:23 PM
SIR 1.6's Avatar
Icon3 Factory Steering Bump Issues
Hi everyone. I am new to Honda-Tech but have been a reader for some time. My project is a 91 CRX Si that is bone stock. Bought it too years ago with 200k on the odometer. Car is a ZC swap with no suspension mods. My problem is whenever i hit a puddle of water, or speed strips or any bump that isn't even, the car pulls violently to the side of the bump. Took apart the entire front suspension, and for 200k car thats over 20 years old all the bushings were tight and solid. Tie rod and ball joint boots were shot, but the joints themselves were fine (replaced boots new grease). Car came with 205/45 Z 16 sumis. Not sure if its the size tires or what, but with no play in the joints/bushings or the rack i'm at a loss as to why it bump steers. Car is a real survivor but this one issue sucks. Any help would be great, And thanks for being a resource for me in the past!
Old Jul 29, 2012 | 02:48 PM
SIR 1.6's Avatar
Default Re: Factory Steering Bump Issues
bump. Anyone got any ideas?
Old Jul 30, 2012 | 07:26 AM
MRZCCRX's Avatar
I had the same problem . Once i did my rear disc conversion problem went away . Check the rear might not be the front end .. Good luck
Old Jul 31, 2012 | 12:24 AM
SIR 1.6's Avatar
Thanks so much for responding MRZCCRX! Took apart the ENTIRE front suspension and drove it for the first time tonight. it helped the bump steer a lot, but still pulls. Ill look at the rear next, car came stock with rear disk any particular thing you did when you did your conversion?
Thanks Again!
Old Jul 31, 2012 | 10:46 AM
MRZCCRX's Avatar
No i had drums so everything other than the toe arms are off a dc integra , but when the old set up came off i did notice a slight bend .
Old Jul 31, 2012 | 12:00 PM
DCRB's Avatar
have you gotten an alignment since you did all this work? and not just a front a 4 wheel alignment? also are you lowered at all?
Old Jul 31, 2012 | 12:09 PM
crx_arturo's Avatar
i had the same problem when i got my crx but i put a camber kit and adjusted the toe links and the problem went away
Old Aug 1, 2012 | 12:35 AM
SIR 1.6's Avatar
@DCRB. No haven't gotten an alignment yet, cheapest ive found is 80 bucks, and being a student thats kinda a lot right now. Car is not lowered, it has stock shocks and springs. Bone stock 91 Si, only difference is the 205/47 16 sumis.
Old Aug 1, 2012 | 12:36 AM
SIR 1.6's Avatar
@ crx arturo. Did yours have 16's too?
Old Aug 1, 2012 | 09:05 AM
crx_arturo's Avatar
no i have 14s and my car is lowered
Old Aug 2, 2012 | 06:53 AM
Todd00's Avatar
I said I don't want a title!
This post is pure speculation until you get the car on an alignment rack.
Seriously...no one can help you until this happens. If they align perfectly and the car still does it, then get back to us.
And lol @ 200K mile bushings still being "solid". If you plan to keep the car, replace the bushings the next time you decide to take the front suspension apart.
slob20ef
Suspension & Brakes
Jun 19, 2011 06:03 PM
jaje
Suspension & Brakes
May 4, 2007 01:07 PM
turnsignalandy
Apr 28, 2007 11:20 AM
JDMlyfestyle
May 31, 2005 09:11 AM
sabertooth
Jan 22, 2004 06:17 PM
