B16 EF fluctuating a/f ratio+ignition timing at Idle
Old Jul 27, 2012 | 01:24 PM
DOHCDAN's Avatar
Default B16 EF fluctuating a/f ratio+ignition timing at Idle
Okay Ive been struggling with this problem for a couple months now and tried everything I can think of.
The air fuel ratio on my aem wideband will start out lean when i start it up, around 17 or so then richen up to 14.7. Once it gets to that point it starts fluctuating between 14.7 and 15.9 every 5 seconds or so.
When I go and check the ignition timing it flucuates in and out of spec at about the same rate as the a/f ratio does.
The car runs decently down the road, but doesn't have the power it should.
Ive tried everything i could think of.
Oil pressure is good, so is Fuel pressure.
Bled coolant
reset ecu
swapped out ecu for know good one
set idle screw to spec
Old Jul 28, 2012 | 08:18 AM
DOHCDAN's Avatar
Default Re: B16 EF fluctuating a/f ratio+ignition timing at Idle
anyone?
Old Jul 28, 2012 | 02:32 PM
villc713's Avatar
Are you running a chipped ecu?
Old Jul 28, 2012 | 05:13 PM
DOHCDAN's Avatar
Yeah a p28 chipped with crome. I put a p30 basemap on my other p28 which is brand new and is outfitted with neptune rtp, hooked it up. same exact thing.
Old Jul 28, 2012 | 09:53 PM
cjmcleod's Avatar
your wideband o2 sensor could be going bad
sh!ft
13
Mar 28, 2013 08:03 PM
stackedhouse
Engine Management and Tuning
May 30, 2012 03:50 PM
bustah49
Sep 23, 2007 06:59 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
