WTB: D16Y7 heat shield|timing belt cover|OEM shifter handle|TAN plugs
As the title states I'm looking for a stock Y7 heat shield for the header(the one with the cat built on the header) I'm also looking for a upper timing belt cover, the one that covers the cam gear. I need the shifter handle(the part you actually grab and use your thumb to press the button to move it in and out of gear) and TAN plugs. The little plugs that go by where you would have fog lights, or down by the e-brake handle.
The shifter also has to be tan.
Thanks HT!
Thanks HT!
I got upper timing belt cover a black civic shift **** standard 5speed and I got some switches from a eg and ek
I think this one is the one that you are looking.
http://i946.photobucket.com/albums/a...2/DSCN3585.jpg
