where to get new pins and crimpping tool
where can i get new wiring pins for the sensor plugs/ecu/etc???
also where can i get the pin crimpping tool so its new like factory??? a link or the actually name would help, thanks
Joel @ speed theory racing development will be able to set u up with everything u need as far as the pins go, u may have to reuse some of the rubber grommets from your existing connectors. As far as the crimper goes its just a standard weatherpack crimper which you can get almost anywhere. I believe he sells them as well though if you just want to get everything one shot. Give him a shout.
Newunitedracetech.com is where I got all my stuff. Good customer service, website is slower than hell but has everything.
Justin @ New United is good to deal with, however most customers aren't aware of what mfg/series connector, the matching terminal, and proper tooling; so you may be pay a few cents more per piece, but you can say "im using this sensor, this chassis, what do i need" and be done with it. These manufacturers have extremely annoying catalogs to sift through.
Let me know if I can help at all.
cehcivic15
Dec 7, 2008 08:09 PM
