96 honda accord 2.2l vtec
I had a blown water pump.
Took of the:
Altenator, power steering, harmonic balanacer, all the belts, motor mount, belt covers, water pump
Replaced the water pump and timing belt.
Weep holes seemed good so I didn't touch them.
My TDC was offset a little towards the back which I was told was normal. But when turning the crankshaft to tdc it hits tdc a little before the cam lines up with the tdc mark. I tried starting the car with tdc set on the hash marks instead of actual piston No.1 tdc.
i smell gas when i try to turn it over and im getting sparks from all 4 cylinders.
how do i fix the timing being off?
is the timing the reason the car wont start now?
thanks for any help you can offer.
Took of the:
Is it 180 out? The camshaft spins half the speed of the crankshaft. It "should" run if it is off by a tooth or so, just not really good. however, if it is 180 out, then the valves open backwards. Intake during exhause exhaust during intake.
It's off by about 6 teeth. How would I adjust that?
Edit:
The water pump was busted up pretty bad and the timing belt kept slipping off when I was trying to set tdc before changing both parts. I ended up pulling off the belt replacing the pump and setting tdc with no belt on. Also the spark plug wire shafts were melted in to my valves and I had to bust them apart with an ice pick and a hammer. Could it possibly be the valves?
Edit:
