00 Civic - Speedometer, turn signal, gear slippage, and idle problems
i have a 2000 honda civic ex 2 door coupe all stock motor....
my car has a couple issues that i want to fix in order to get the car running up to par.
if anyone can help me out or give me some advice on fixing these problems or at least identify why its happening so that i can see how to fix it. the help is GREATLY appreciated!!
problems:
the odometer gauge goes crazy, jumping and down mphs and not stopping or staying steady
no turn signals, bulbs work and all fuses are ok
third gear slips occasionally, not all the time
car idles extremely low, less than 1000 maybe even less than 500 rpms
car idles even lower when i turn the AC one, sometimes the car shuts off because of this
your help is greatly needed and appreciated!
problems:
Check all your grounds, Up front by the headlights are a small tan/whitish box bolted to the car. It comes off the headlight wire harness, Make sure they are bolted on via 10mm bolt and the connection to car is clean.
I would assume the car is Auto seemings how only 3rd slips?
Idle issue= how the exhaust? still has cat? Could be plugged up.?
mnskateboarder
Apr 30, 2011 08:38 AM
B16Power
Jul 19, 2005 02:51 AM
