D series and B series engine + more
Old Jul 25, 2012 | 06:11 PM
2slowGs-R's Avatar
Default D series and B series engine + more
Pictures up!
-LS (B18A) Block (Like new with less than 9K miles) ($800.00) price lowered
-ITR RS Machine Piston 81.5mm<br>
-ARP Rod bolts<br>
-ARP Head Studs torqued once<br>
-ACL bearings replacements<br>
-Shotpeened LS Rods<br>
-this block comes with the oil feed line for this head
-Ported and polished GSR Head ($400.00) tapped and ready for LSR
-Stock valvetrain
-Stock Cams
-No IM or throttle body
-the head is made to run an ls vtec or straight Gsr/SI, by taking off an Allen head to swap it and plug one or the othe hole to run what u want.
-Stock SOHC ZC Longblock with about 60K miles still hella clean when valvecover is opened. ($500.00) oil change every 2500 miles with Castrol GTX 5W30
-y8 IM
-LS TB
-I believe this is an OBD2 ZC.
(no Dizzy/Alternator/Clutch/Flywheel)
88-91 Honda Civic parts
-4 door EF seats F/R ($100.00) Driver side is ripped but all others are good cond.
-4 door EF custom exhaust 2.25 inch all the way.( $200.00) crush bend
-power window options for 4 door EF ($100)
Txt or call me @ 559916.70two-six if you are interested.
Old Aug 16, 2012 | 11:42 PM
2slowGs-R's Avatar
Default Re: D series and B series engine + more
this engine made 196WHP and 133lbs of torque!! with aftermarket cams and valvetrain!
TekBuDDy
14
May 30, 2014 09:06 PM
BlkTegOn18s
Aug 18, 2010 07:15 PM
wernhersey
Jul 30, 2008 08:00 PM
her-dc
Apr 21, 2007 09:16 AM
AK77
Feb 15, 2007 10:51 AM
