Bad alternator?
Old Jul 25, 2012 | 01:55 PM
lxaccord51oxl's Avatar
Default Bad alternator?
So I finally got my car to start. Now I am checking my alternator. The original voltage on the battery is at 12.4v when the car is off. When the car is on, the voltage meter reads some where between 13.5-14v. But it jumps up and down. Here is a video to show what I am talking about. Is this normal? I've seen other videos on good alternators where the volts stays consistant.
97 accord LX 230k miles
http://www.youtube.com/watch?v=sXViW-Unu84&feature=plcp
Old Jul 25, 2012 | 02:02 PM
nus_dogg's Avatar
Default Re: Bad alternator?
Whats the symptoms? Is the battery light on?
Old Jul 25, 2012 | 02:03 PM
The battery light flickers when the car sits at a stop light.
Old Jul 25, 2012 | 02:10 PM
nus_dogg's Avatar
Then it's on it's way out. The one on my H22A does that at idle. Actually, it stays on at idle til I get going then it shuts off. I drove on it for a whole day, swapped it out for a new one and problem fixed.
Should be a constant 13-14v running.
Old Jul 25, 2012 | 02:24 PM
That's odd because i've just changed the alternator a year ago. Do the alternator go out that fast?
Old Jul 25, 2012 | 02:58 PM
tim73's Avatar
Get the alternator tested. But before you do that, see if you can remove the brushes from it. On occasion they will get stuck and wont be making good contact with the armature. or maybe one will and one wont. Sometimes if you take a rubber mallet, smack it, and the brushes will reseat. But, if it is under warranty, say you got it at autozone or wherever. Then you can just swap it out. but to answer your question, those parts store alternators/or starters, are not built very well.
Also, is there oil or crap on the alternator, wiring? bad connections SO many times mess with people trying to figure out electrical problems.
Old Jul 25, 2012 | 05:55 PM
nus_dogg's Avatar
Not really. A new can go bad anytime though just like saying a brand new part can still be defect right out the box.
Old Jul 25, 2012 | 06:27 PM
At first i thought that the belt on the alternator was loose, is there any way I can tighten up the belt?
I believe that there is some powersteering fluid on the alternator since my powersteering pump is leaking fluid. You can see some fluid leaking out of the power steering pump from the pic in the other thread i made.
https://honda-tech.com/forums/honda-accord-1990-2002-2/am-i-missing-something-3074850/
Will this cause the alternator to act up?
NYHC4G63
20
Mar 7, 2012 04:32 AM
89edcivic
Sep 26, 2009 02:38 PM
SupraRXZ
Mar 20, 2007 07:52 AM
pstutz
Apr 26, 2003 12:05 PM
crxtreme27
11
Aug 28, 2002 11:29 AM
