93 cx b18b1 smoke
Old Jul 25, 2012 | 12:14 PM
Myztiq's Avatar
Default 93 cx b18b1 smoke
Hello name is Jesse.
i own a 93 civic hatchback with a ls swap recently it started to smoke when on stop lights and long stops never did that before unless i step on it (until oil change and i drove it for like 3-4 hours in 106 weather)
i use bosch oil filter with mobile 1 10-30 full synthetic
when i checked the oil level it was not marking so i took my other car to work because was running late so i had called my brother to go buy some quarts to fill it up between the low n high marks
(car was warmed and was not cold) but i got home from work did not check it out till the next day it was past the High mark
would it make it smoke like that
(please keep in mind that has a rebuilt head and new piston rings headgasket)
i checked the pvc valve it clicks good there was oil residue on it (car was running operating temp pcv removed clicked find) would this be the cause of overfill
any help would be considered
thx
GoodUsername
Mar 9, 2015 04:59 AM
jdmeg6118
16
May 1, 2010 07:02 PM
boostedjdmdc2
Jan 26, 2009 04:55 AM
BigZeke5
Nov 11, 2008 07:23 AM
714
Feb 4, 2003 04:37 AM
