ECU needed for a swap/ fitment.
Bought the 91 LS motor from CL, the seller gave me an ECU and he said its belong to the motor. When i hooked up and find out its bigger than the others ECUs and won't fit in 4 bolts where used to mount it in, but it can start !
Does anyone have this issue ? if not , he must gave me a wrong one, then can I use my old 90 DX's ECU for 91 LS swap ?
Thanks, D
Thanks, D
BTW - your DX ECU will NOT work for the LS swap. The stock DX engine has a two injector (dual point fuel injection) set-up, whereas the LS engine/ECU has the 4 injector (multi-point fuel injection) as well as different inputs for other sensors too.
Is this swap completed? Did you already do the dual-point to multi-point swap?
Come to think of it you may not be able to wire the injector resistor box in, I think that the LS injectors are high impendance no? You will have to measure the resistance on the injectors.
Good points Guys !
i am almost done with the swap and just concerning about the ECU mounting fitment !
so far, the engine can starts but haven't ride it yet since i have to work on power steering hose replacement.
yea just check those injectors, i believe the 94-95 obd1 b18b ls motors have 235 cc injectors but they were high impedance, which would mean do not wire in a resistor box while doing the swap/build.
If obd1 p75 there is no need for the resistor box unless running bigger injectors....and to answer your question a obd1 ecu has the mounting points in different places than the pre-obd counterparts
i got almost the same question but i got a ef si and i got a d16y8 for it what computer can i use for it can i use any of thr obd0 ecu or whst do i need to get
help
help
Ok guys this is the clip that we ( OP and I) recorded earlier from the ECU ....can anyone explain what does this means ? By the way , the tag on his ECU said " AR" so is this the right ECU for him to use on his LS swap?
http://s230.photobucket.com/albums/e...t=90897666.mp4
ECU Codes <-- clickable
1) take it out and clean it?
2) replacing it?
3) or maybe we mixed up w the wrong hose?
4) thoughts?
I will do that but we are at loss on the vaccum line on this motor . Does anyone has the pictures to show where we should hook up all the metal hoses on the IM ?
We also noticed that the throttle response is very slow . It sounds like the intake suck alot of air then the IM rev it ... I mean it just takes forever to get to 40mph ( I really have to step the gas pedal down to get to that speed) . Could it be the vacuum line ?
