lowering 97 accord
I'm lowering my 97 accord 2 in. and is it going to throw the scrub radius off so bad that im going to be trashing ball joints and wheel bearings all the time? or can I get by without a camber kit?I'm asking because I know that it effects different cars in different ways.
lolwut?? negative camber is good for you haha
the guys who dump their **** on the ground and run hellaflush break stuff all the time if they drive normal
just get alignment set to zero toe or yo will killa brand new set of tires in 8K miles
I just lowered my CE wagon and noticed one of my upper arms balljoints was leaking. I'm going to chuck it up to the car being 19 years old, vs. the strains of lowering.
Just do it, get an alignment. If you don't like the camber settings get a camber kit. Simple as ****.
You will need camber kit. I'm dropped on 1.5" all around and I would go through tires every 5-6 months. Tire worn has slowed down for me with Ingalls camber kits all around.
several alignemnt guys have all told me the same thing over the years: Camber setting does not wear your tires, its the toe being thrown out of wack from constatly dismanteling/ altering your suspension.
first: install your new spring strut, if coilovers then adjust to a height you are comfortable with and wont have to mess with anymore
then take to an alignment shop and have them fix the toe setting. i did this to my old integra and drove it to work everyday for over a year to work 65 mile round trip and the tires wore evenly. After that year i sold the car to a friend who beat the living **** out of it running over potholes and speedbumps w no remorse so that finally messed it up.
I have 2 accords and they both are lowered on function form suspension the wagon has camber front and back and the 4dr doesn't have any camber and i haven't had no problems with either yet. wagon had it for about a year now and the 4dr like 3 months.
wagon has 18x9 and 4dr 18x7.5 and don't have no prob with none.
I just aligned my wagon today, and the camber in the front is different by 1*.
2.5 driver, 1.5 passenger.
Needless to say I'd like to get a kit to even this out.
I remember reading somewhere you can use EF Civic camber kits, does anyone remember if that's front or rear?
What's a good brand that doesn't run too expensive?
Thanks.
Thanks.
Thanks.
Thanks.
grimace1425
Oct 28, 2016 12:31 PM
