oil in spark plug tubes
Old Jul 24, 2012 | 03:38 PM
dwils's Avatar
Default oil in spark plug tubes
i have a d6a6 with a misfire and im pretty sure its cause i keep getting oil in the two middle spark plug tubes ive changed the valve cover gasket 3 times with the spark plug grommets and yet i still find oil in there. has anyone experienced this problem before or know how to fix it? im about to try oem valve cover gasket and oem grommets just to see if that will fix it
Old Jul 24, 2012 | 04:46 PM
4drEF's Avatar
Keyboard Humorist
Default Re: oil in spark plug tubes
When you remove he grommets, can you find any evidence for where the oil is breaching? Might need a little help with Hondabond or the 3M yellow stuff.
Old Jul 24, 2012 | 05:50 PM
Kaze-Speed's Avatar
I would replace the gromets and use some silicone on them as well.
Old Jul 24, 2012 | 05:53 PM
dwils's Avatar
is that safe to do?
Old Jul 24, 2012 | 05:58 PM
Rand The Man's Avatar
Replace Vavle cover gaskets.
Old Jul 24, 2012 | 10:01 PM
dwils's Avatar
just replaced it still have popping of the exhaust
Old Jul 24, 2012 | 10:28 PM
93delsold16z6's Avatar
Popping of the exhaust means u are running rich. not oil on plugs.....
Old Jul 25, 2012 | 04:30 PM
dwils's Avatar
running rich would mean timing right? my timing was checked and is fine
Old Jul 25, 2012 | 05:00 PM
~sp33~'s Avatar
EFB055
Running rich means there is too much fuel to air.
Check the vac lines to your map sensor.
Old Jul 26, 2012 | 03:09 PM
dwils's Avatar
check for what leaks and cracks?
Old Jul 26, 2012 | 03:19 PM
dwils's Avatar
im running a aem cold air intake and a dc header if that changes anything
Old Jul 26, 2012 | 04:00 PM
~sp33~'s Avatar
EFB055
Yep.
Old Jul 27, 2012 | 05:29 AM
dwils's Avatar
no leaks or cracks found
Old Jul 27, 2012 | 06:17 AM
wanabebuff's Avatar
As far as the oil in the spark plug tubes goes, if you've already replaced the gaskets, ensure you torqued the valve cover to the proper specs.
For the misfires and running rich, check your plugs and see what they look like. They could be fouled
Old Jul 27, 2012 | 06:42 AM
LSx Envy's Avatar
As for the oil in the tubes the D16A6 has two areas in each sparkplug tube where oil can get in..
The first is the obvious one with the grommets that are on the valvecover gasket..
The other is a set of O-rings that are under the rocker assembly... Bet thats your oiling issue...
Pull the plug wires and look down in the tubes with a flashlight.. You should be able to see the seeping about half way down..
I personally went to do this a couple weeks ago on my A6 and found some coolant milkshake on mine.. lol.. So I had more work cut out.. But make sure you have an In/lb torque wrench ready for re-assembly to torque down that rocker assembly... Everything else is straight forward just follow the manual..
Old Jul 27, 2012 | 08:51 PM
dwils's Avatar
so ive come to this conclusion i have a bad distributor lol checked the timing belt its all lined up threw the timing light at it notice its to advanced and we retarded it as far as it would go and it still isnt in spec. my solution is im building a vtec head for it and thats what im going to put on it probably by next week lol
Old Oct 9, 2012 | 07:03 PM
GT500FTW's Avatar
Oil in the plug tubes could technically cause popping from the exhaust.
If there was enough oil to cause the plug to fire too late - causing a resistance through the oil- effectively retarding the timing on that specific cylinder, then the fuel/air mix might be igniting just before the exhaust valve opens, causing a popping sound!
Old Oct 10, 2012 | 12:47 AM
BIGef's Avatar
as for the oil in your spark plug area.
i would say its the o rings under the rocker arm.
changed mine today and stopped leaking.
I hope sooo...
Old Oct 12, 2012 | 07:48 AM
babyj86zc's Avatar
Need new grommets and might as well get a valve cover gasket.
Old Oct 14, 2012 | 08:30 AM
wasp9166's Avatar
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals
do it
Zendos
Nov 4, 2009 04:04 PM
EG6_978
Sep 13, 2008 02:37 PM
keychild486
Aug 15, 2008 04:12 PM
sprco
Jul 2, 2008 09:54 AM
cxVtecC1
Jan 16, 2005 05:00 PM
