Transmission & Drivetrain Gearboxes, Differentials, Clutches
b18a1 Trans options
Old Jul 23, 2012 | 09:00 PM
F'nHonda's Avatar
Default b18a1 Trans options
i Need help just blew my trans a huge hole in it, any way i have a b18a1 not shore the exact year of it but know it has 150 been boosted now on a 57 trim for 10 months tuned by Dk goodrich boost by gear 1st 8 2nd 8 3rd 12 4th 12 5th 8,
so i have a few Noob questions
-does it have to be re-tuned now that there will be another trans
-what Trans should i replace it with
-can i have LSd in a cable trans
-if so whats the price range im looking at ?
-can i do a b16 cable trans ?
Old Jul 24, 2012 | 07:17 AM
type_r_ek's Avatar
Default Re: b18a1 Trans options
id do a cable to hydro conversion, find a b16 or itr trans, and yes i would reccomend retuning due to changing a trans changes the whole cars function, shorter gears will be alot different than an ls, also id put your ls 5th in it for fuel economy, hope that helps
Old Jul 24, 2012 | 01:49 PM
94EG8's Avatar
Seagull Management
YS1 cable case is what you want, they came in all '92 - '93 Integras and you can run hydro guts in them. You will need a '92+ B-series clutch with a '92 - '93 Integra throwout bearing.
Yes you can run an LSD in a cable trans.
Old Jul 24, 2012 | 09:09 PM
Mista Bone's Avatar
D Tranny Guru
OP, Middletown OHIO?
Old Aug 9, 2012 | 03:45 PM
F'nHonda's Avatar
Yah Ohio, and thanks ya it did help and I'm just gonna get another ls a1 trans so it hopefully dosent change that much ill get a tune later don't have the cash for that after this replacment
Dec 10, 2006 08:19 AM
KuyaCyd
Oct 4, 2004 08:17 AM
iwouldHITit
Jul 10, 2003 05:49 AM
