Hasport Engine mount Problem
Old Jul 23, 2012 | 12:51 PM
Steeve_Civic's Avatar
Default Hasport Engine mount Problem
My driver Hasport engine mount doesn't fit on the car
Do I need to change the OEM engine mount by a 3 bolt one or is there another Hasport Mount exist?
Because I bought an OEM 3 bolt engine mount but cannot fix the steering wheel with it.
Here is my Hasport mount with my OEM engine mount
The other OEM 3 bolt engine mount that fit the Hasport mount
But cannot connect here the steering wheel
Old Jul 23, 2012 | 01:00 PM
civickiller's Avatar
Default Re: Hasport Engine mount Problem
what chassis and engine mount, years?
Old Jul 23, 2012 | 01:03 PM
Civic EG 1994.
Perhaps this one will be fine?
Old Jul 23, 2012 | 01:32 PM
phunhaus's Avatar
Change to the cast three-bolt bracket.
Old Jul 23, 2012 | 01:36 PM
If I fit the Cast 3-bolt Bracket I cannot fit the steering wheel anymore.
Old Jul 24, 2012 | 09:53 AM
Do you know how to reconize the durometer rating ?
Old Jul 24, 2012 | 04:24 PM
MonkeyMagic's Avatar
the power steering bracket bolts to the engine mount??
france can't be that crazy.
Old Jul 24, 2012 | 06:12 PM
Rand The Man's Avatar
Yeah that looks insane another pain in the rear under the hood i reckon
Old Jul 24, 2012 | 09:07 PM
lassek20's Avatar
the power steering pump should bracket have 2 other bolts that mount to the engine with the 3rd connecting to your side engine mount bracket. you should be fine omitting that 3rd bolt to get the side bracket you need to work..or you could always drill and tap..
Old Jul 28, 2012 | 09:40 AM
Are you sure I can remove one?
How your steering wheel connecting in USA?
Above
Under
Old Jul 28, 2012 | 12:37 PM
lassek20's Avatar
same set for usdm cars. you can get by without using that one bolt if needed
Old Jul 28, 2012 | 01:08 PM
I can get out this bolts and the 2 under the steering wheel?
eviee1973
Honda Civic (2001 - 2005)
Jun 24, 2013 05:40 PM
B00M3R
Feb 17, 2010 02:02 AM
fastcrx420
Oct 25, 2009 04:48 AM
lowlight
13
Dec 3, 2004 05:32 AM
