96 civic front crunch, no spark now
Old Jul 22, 2012 | 05:19 PM
9205bgood's Avatar
Default 96 civic front crunch, no spark now
Hit a culvert and the air bags blew. now it cranks but no spark..no start. Check engine stays on with key on. SRS also on. Put a diagnostic tester on it and it won't recognize it. It powers up but says not communicating. I think the engine shut down on impact which is lucky...if you can call hitting a rock culvert lucky, because a rock cut a hole in the oil pan, and the transmission. Replaced the transmission and the oil pan. Now I have no spark to plugs. Was hoping the OBDII tester would help but it's not reading it. HELP!!!!!
Old Jul 22, 2012 | 05:40 PM
Former User's Avatar
Default Re: 96 civic front crunch, no spark now
Does the fuel pump prime?
Is fuse 13 or 44 blown?
Old Jul 23, 2012 | 05:47 AM
9205bgood's Avatar
will either of these fuses cause us to not have spark?
WAIT!!! Fuse 13 was popped. It started!!!
Thanks RonJ
Codyaz
Feb 4, 2017 04:26 PM
Huntera
Dec 9, 2016 10:00 AM
living702
Feb 10, 2008 11:52 AM
Fatty_1775
Jun 12, 2007 10:40 PM
valerie34
Jun 30, 2005 07:42 AM
