Honda S2000 Honda S2000
S2000 suspension problem...toe arm not lining up!
Old Jul 21, 2012 | 04:02 AM
em1effekt's Avatar
Default S2000 suspension problem...toe arm not lining up!
i was recently involved in a hit and run wich made me to spin in cirlces a couple times
i hit the curb wich caused my rear wheel to fall off causing damage to the suspension (rear passenger side)
so i went ahead and purchased what i needed...knuckle assembly...lower and upper control arm...caliper...axle...tie rod...
almost done with everything and i noticed the tie rod isint lining up... could this be because i am using a left tie rod on the right side
or could my subframe be bent?
if i put it into the subframe first and then the knuckle..it will not go into the knuckle...
Old Jul 21, 2012 | 04:17 AM
em1effekt's Avatar
Default Re: S2000 suspension problem...toe arm not lining up!
okay so i did some research and what i have found is that the left and right might not be interchangeable
this link shows two part numbers one for the left and one for the right
http://www.hondapart...R%20LOWER%20ARM
if they were interchangeable im assuming it would be like the end link one part number for both sides (#8) ?
Old Jul 21, 2012 | 04:57 AM
Boots's Avatar
its just like our axles...i believe the driver side arm is slightly longer
Old Jul 21, 2012 | 10:16 AM
em1effekt's Avatar
not having a problem with the length...having a problem with it lining up..
it will go into the subframe good but wont go into the knuckle good cause it is a little far to the right...and if i try putting it into the knuckle first and then the subframe...it will look like this
Old Jul 21, 2012 | 10:21 AM
Boots's Avatar
did you buy the right knuckle? i think AP1's are different than AP2's
Old Jul 21, 2012 | 10:37 AM
em1effekt's Avatar
damn..your right..i just checked the part numbers on it...
ap1
3 52210-S2A-000 KNUCKLE, R.
4 52215-S2A-000 KNUCKLE, L.
ap2
3 52210-S2A-010 KNUCKLE, R.
4 52215-S2A-010 knuckle L
is there anyway i can check if i have the rite one?
Old Jul 21, 2012 | 10:45 AM
Boots's Avatar
take it off and see if theres a part number on it is really the only thing i can tell you
Old Jul 21, 2012 | 11:11 AM
em1effekt's Avatar
checked it rite now..there is no part number on it..but i am sure i have an ap1 knuckle..
ap2 knuckle looks way different...so now only leads up to bent subframe or wrong toe arm
ap1
ap2
Old Jul 21, 2012 | 11:27 AM
em1effekt's Avatar
i know the ap1 and ap2 tie rods are interchangebale.....
but if right and left are interchangeable...the only thing i have left would be the subframe
Old Jul 29, 2012 | 11:29 PM
em1effekt's Avatar
found out ap1 and ap2 toe arms are the same right and left are the same
so my subframe is bent
chewe
Apr 9, 2017 03:41 AM
cricketracer
Honda S2000
Jul 8, 2016 07:47 AM
rallybird
30
Apr 19, 2006 04:12 AM
dreww..
Suspension & Brakes
Nov 10, 2005 03:00 PM
