Ek Hatch : ASR SUBFRAME + ASR SWAY BAR
I recently ordered a 24mm or 22mm forgot which .. from ASR . Sway bar .
and the subframe. I also ordered the endlinks.
But im not sure how to put the sway bar in. I have it installed to the subframe etc on the rear frame etc. but the sway bar ends i do not no where the 2 wholes need to connect to. or even how to connect the endlinks in ! D: i know the endlinks are supposed to go into the LCA's .. but which end? goes on the subframe . ive did so much research and i can't seem to find the answer!
or even which holes i use to connect the adjustable endlinks to the lca !
HELP ME PLEASE D:
.. the endlinks are from passwordJDM !
remember this is all going on a ek hatch! if im missing a part lmk please !
thanks!
HELP ME PLEASE D:
.. the endlinks are from passwordJDM !remember this is all going on a ek hatch! if im missing a part lmk please !
thanks!
there are 3 holes . i just wanted to take precaution b4 i start driving .
Your goal should be to have the end links as close as possible to vertical while the car is on the ground. Adjust as needed.
Hard to insult someone when your grammar isn't even correct... Get outta here brain. By the way, your Asian avatar isn't even hot. Sure hope it's not your girlfriend...
not insulting your technical/mechanical expertise. was stating the fact that you called (guessing op) a noob, when the thread is about, a little over 4 months old.
the irony, a noob, is usually the ones bumping old threads out of no where, which is what you just did. you didn't add anything to the thread to help, just wanted to post something to insult someone..... that probably hasn't even looked at this post since August.
oh, and lol to you thinking im a young buck.
dam you really got me on that one!
