Change rod bearings in car - easy?
Old Jul 20, 2012 | 05:58 PM
Horatio's Avatar
Default Change rod bearings in car - easy?
Hi all, I've got a knock in our '95 Odyssey (F22B6 which is why I'm posting here) and I suspect it's from a bad rod bearing on cylinder 3. I'm planning to drop the oil pan this weekend and see if that rod is noticeably loose on the crank by seeing if I can wiggle it. From searching around on here and other sites I've heard of people replacing these bearings with the engine still in the car but is there really room to do this? The way the threads go is something like "I just dropped the pan, popped the rod cap out..." and so on. The way they make it sound is that there's no issue working with the crank girdle in the way while under the car. Is it really that simple to get at them? Has anyone here done this?
Thanks!
Old Jul 20, 2012 | 07:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Change rod bearings in car - easy?
The early Ody is based on the Accord chassis, if so all you really need to do is remove the splash shield, center beam, and the oil pan.
The 94-97 Accords are stupid simple to work on the engine. Especially with the oil pan. Before you go about replacing bearings, pre measure them with some plastigauge, to verify that the rod bearings are toast.
Mitch11Bravo
Feb 26, 2015 08:42 AM
pjr710
Aug 18, 2008 11:18 PM
ulemu
12
Jan 3, 2006 12:37 PM
Sinner
May 15, 2003 04:48 PM
B20zvtecek
Oct 28, 2002 07:11 AM
