Koni & GC
Im using this car for street its my daily. What is the best spring rate close feeling to stock? I have search and I havent found much info. I heard koni and gc is really good and its cheap compare to others. Deciding to get this but need spring rates suggestion or should I go with other brands. Help please thanks!!
go with whatever the off the shelf rates are. keep in mind koni yellows for this chassis are just inserts and require you to cut up the stock struts to make them work.
If the car is your daily driver then I highly recommend the a-spec suspension kit. It lowers the car about 1" and handles a lot better than stock without sacrificing much ride quality. It's $650 shipped brand new from curry acura and it comes fully assembled with the tophats. Bolts right on to a rsx, for an EP3 you're gonna need rsx tie rod ends and shave the rear shock bushings about 3mm. If you're really on a tight budget then get a used DC5 type r suspension from ebay, they usually go for about $350 shipped and is basically identical to the a-spec kit.
