Built sleeved eg part out
I have decided to go a completly different route so i will be parting out my build. I will ship items at your expense. I would like to keep the long block together but if i get offers i like for the head and block i will seperate. Call/text 608-698-5911 PICTURES WILL BE ADDED ASAP
Complete block and head $3600 obo
Block (3000 miles)
B18c1 sleeved with Darton MID kit bored to 84mm
Brian Crower turbo rods with arp rod bolts
CP 9.0:1 pistons with upgraded wrist pins
Oem crank polished, balanced, and lign honed with block
New oem oil pump, water pump, and all seals
Moroso oil pan with turbo return and oil temp bung's
Cylinder Head (3000 miles)
97 integra type r head
Supertech valves, dual valve springs and retainer
Type r cams
Arp head studs
Cometic head gasket
Type R LSD transmission $1500 obo
Carbon coated syncros and heat treated gears
Moroso catch can w/ -10an lines and fittings $100
Act Xtreme clutch kit (300 miles) $400
Edelbrock performer x intake manifold b16/type r (powder coated purple) $250
Mac boost solenoid $40
Hasport engine mounts $250
Aem silver fuel rail $75
Rc 1000 injectors $250
Turbo Setup:
Garette GT3076r with precision .63 exhaust housing (1000 babied miles) $1100
LoveFab ram horn exhaust manifold w/ 44mm wastegate flange
Precision 46mm wastegate (everything that comes in the box new) $250
Hot and cold side intercooler piping $150
No name intercooler (supported 450 hp on previous build) $200
Greddy type s bov $125
Glowshift egt gauge w/ temp probe (new) $80
Autometer boost guage $30
Glowshift oil pressure gauge w/ sending unit $40
Aem wideband gauge w/ sensor $125
Black personal neo grinta steering wheel w/ red stitching $175
Black tilt hub $200
15in black with purple lip rota track r (bfg g force tires) $600
Tein basic coilovers (great working order) $550
Hondata s300 in p28 ecu w/ boost by gear $650
Block (3000 miles)
Type r cams
Arp head studs
Cometic head gasket
Turbo Setup:
Black tilt hub $200
str8boostn
Sep 2, 2006 09:59 PM
