MPH In Cluster Jumping!
Old Jul 18, 2012 | 10:45 PM
Dazer 1991's Avatar
Default MPH In Cluster Jumping!
Is this a simple fix?
Old Jul 19, 2012 | 08:25 AM
4drEF's Avatar
Keyboard Humorist
Default Re: MPH In Cluster Jumping!
your speedo cable.
Old Jul 19, 2012 | 09:16 AM
Dazer 1991's Avatar
I thought it would be a sensor or something. hard to fix?
Old Jul 19, 2012 | 09:25 AM
4drEF's Avatar
Keyboard Humorist
Have you been working under the hood near the transmission? Maybe even have had the speedo cable disconnected for any reason?
Or have you been working on the dash and have had the cluster out?
Usually the jumpy speedo is from a cable that's not connected properly.
Most commonly it's somebody that had been working on the transmission, disconnected the cable, and then lost the clip shown in this image when reconnecting
http://i294.photobucket.com/albums/m...Face/crx/4.jpg
That's an easy fix.
If not, then you can try shooting some lithium grease into the cable, but I would just replace it.
Not super hard, but if you aren't comfortable removing the cluster then it's probably something you shouldn't do.
Here's a walk though on a CRX.
Same thing with Civic
http://crxcommunity.com/viewtopic.php?t=43624
Old Jul 19, 2012 | 09:38 AM
Dazer 1991's Avatar
I believe it got stolen into before. the center console is diffrent. under dash fuse cover is gone. and i noticed he changed out the ignition coil when i changed the dizzy cap. So yea its possible he couldve done that
peanut butter
Feb 18, 2008 04:00 PM
da9blk1
Sep 5, 2007 11:10 AM
93egryda
Mar 15, 2006 11:16 AM
Civicracer17
Mar 13, 2006 04:49 PM
cutt
Nov 12, 2004 06:57 PM
