stripped metal for window handle
Old Jul 18, 2012 | 05:45 PM
SiRCiviC94's Avatar
Default stripped metal for window handle
can the gold piece with thread for the window handle teeth be replaced? easily... since someone put a wrench on it and just grinding it to **** it ruined 3 handles already (even using a flat head to straighten up the grooves didnt help)
Old Jul 18, 2012 | 06:00 PM
CO671's Avatar
Default Re: stripped metal for window handle
I don't know about gold piece but are you referring to this?
Here's my thread about it I made last month if you want to read further into it.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/window-regulator-3066769/
Old Jul 18, 2012 | 07:12 PM
SiRCiviC94's Avatar
this car has aftermarket power locks, I could splice into an EK4 door (jdm) and use the power locks off there? those doors come with power windows though which id like to wire up if possible.
doors are like 75$ each
Old Jul 19, 2012 | 04:41 AM
SiRCiviC94's Avatar
maybe ill just get creative and weld a bolt on handle but the mechanism is also messed up, window goes up 3/4 and then needs pushed up by hand, and tighten the handle after that.
id really like to know what causes that as well !
Old Jul 19, 2012 | 05:34 AM
CO671's Avatar
Oh, good idea. You are talking about the part I posted the picture of, right? However you macgyver it, i'd like to try it out.
Maybe it needs to be aligned or the rubber guides/guards are bending inward instead of around?
Well when you fix it and it's rolled down, might as well align it:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-civic-window-problem-2860099/
Old Jul 19, 2012 | 06:16 AM
purgat0ry's Avatar
Or, replace your window regulator.
NzAnE2K
Jan 2, 2008 12:05 PM
civiceg94
Jul 10, 2007 12:27 PM
dom93hatch
Sep 17, 2002 01:33 PM
