Mid-Atlantic (Sales) VA, DC, and MD
Turbocharged '98 Acura Integra Gs-R Sedan
Old Jul 18, 2012 | 03:45 PM
yeaitsahonda's Avatar
Default Turbonetics, Hondata, Thermal R&D, ETC..
Contact: Reply here or PM, or call/text 540-359-0106 before 9pm. I am up early so early morning is ok.
Price: See below
Description: I am parting out my turbo '98 Integra Gs-R Sedan. The motor an trans are spoken for, but not removed yet. I really want to find a buyer for the turbo kit before parting the car out. So, I am listing all of the drivetrain related parts now and will update this post with everything else tomorrow. I don't want to remove anything until I find a buyer for the turbo kit.
Videos can be seen here:http://www.youtube.com/user/yeaitsahonda/videos
Pictures: I don't have any "good" current pictures. Here is a link to the photobucket album that has some that I uploaded at random points in the cars progress. The ones with the grill put in the front bumper are the most up to date. http://s416.photobucket.com/albums/p...honda/Integra/
1. Turbonetics Kit: $1100
Turbonetics Turbo Manifold
Turbonetics Evolution Wastegate has an 8psi spring in it and will come with an extra 3psi spring
Open dump tube
Turbonetics T3 Turbo
3" Downpipe wrapped in titanium heat wrap
All of the charge piping
Upgraded Spearco intercooler
Turbonetics Evolution blow off valve
Stainless oil feed line
-10AN oil drain line
Precision 550cc injectors
Plug&play OBD2 injector clips so you don't need to solder in new clips
PTuning vacuum block
Custom Catch Can: $70
Catch can is made to mount into the factory washer bottle location of a DC/DB Integra. I had two -10AN lines ran from the front of the valve cover to the can. Has a drain on the bottom and is vented to the atmosphere through the top with a K&N filter.
Hondata S300: $500
Hondata S300 unit in a P72(I am fairly sure that is the number, when I get the car back home I will check to make sure). It does have boost components in it. Everything was installed professionally by Phearable.net. Will come with the OBD2-1 jumper harness.
Mishimoto Dual-Core Full Width Radiator with slim fan: $150
This radiator is almost brand new. It has maybe 500 miles on it. I had the car on track for an hour with only 1 driver change in 90°+ weather and the water temp never went above 210°.
PLX Devices Air/Fuel Sensor Module w/ Guage: $100
This probably has 2k miles on it. Works great with the S300.
Hondata Boost Control Solenoid: $50
Has been on the car about 1k miles. Was only used a few times to up the boost to 12psi and then unhooked because I didn't really want to put the motor through that much stress. Includes mounting bracket
Hondata 3bar Map Sensor: $50
Plug and play Hondata Map sensor. Used for 2k miles.
BNIB Axles w/ lifetime warranty: $100
Not much to say here. New axles from Olympus Imported Auto Parts with a lifetime warranty.
Walbro 255 Fuel Pump: $40
Used for 2k miles.
Thermal R&D Exhaust: $350
This exhaust is on my 4-door 98 Integra, but should fit Civics as well. It is part number B131-C131. It has been used for 2k miles.
From another website:
94-02 INTEGRA 4 DR. all models B131-C131
92-00 CIVIC 2 DR. & 4DR. all models B131-C131
Please check http://www.thermalrd.com/ to make sure that it will fit your car before contacting me. I have no idea what it will fit so please do not ask me.
Some people have already asked about some parts. I am only posting them here in case our deals fall through before the turbo is sold. If I have been talking to you about parts, our deals are still good.
Old Jul 19, 2012 | 04:55 PM
Default Re: Turbocharged '98 Acura Integra Gs-R Sedan
Got no interest on the car so I am parting it out
Last edited by yeaitsahonda; Jul 22, 2012 at 06:19 PM. Reason: Now parting car out
Old Jul 22, 2012 | 06:20 PM
Sunday bump.
Maluko
Jun 28, 2012 09:18 AM
KwunEg6
Feb 2, 2012 07:30 AM
