Door Sill Removal Help
Old Oct 15, 2002 | 11:30 AM
importfan85's Avatar
Default Door Sill Removal Help
What do I have to do to remove the door sills and that whole plastic piece. Help would be appreciated
Old Oct 15, 2002 | 11:57 AM
SiR Kid's Avatar
New User
Default Re: Door Sill Removal Help (importfan85)
You jsut need a phillips head screwdriver...
There are two phillips that you can see when you open the door, it's help on by the usual Honda press clups once you remove the screws. I beleive you pull the black sill toward the front of the car to remove them, but it should be apparent by how the piece wiggles once removing the screws. It's been a while, excuse my ignorance
Old Oct 15, 2002 | 01:22 PM
tommycrx's Avatar
Default Re: Door Sill Removal Help (SiR Kid)
If memory serves, those two bolts are torx bolts, not phillips.
Old Oct 15, 2002 | 02:26 PM
incubus's Avatar
Default Re: Door Sill Removal Help (tommycrx)
my rex uses torx bolts, hatch is prolly the same.
Old Aug 20, 2008 | 07:30 PM
jacksonww's Avatar
Default Re: Door Sill Removal Help (incubus)
Anyone have a clue what size torx bolts are in the door sill? I'm trying to route some wire to the back of the car and need to remove these things.
Thanks,
Jack
EG9_Sedan
Aug 31, 2015 06:28 AM
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
doughboixx
Jun 27, 2007 08:11 PM
Rudaluda
Mar 1, 2006 09:29 PM
B18CYAAA
Jul 13, 2005 03:05 PM
