climate control wiring
I am trying to figure out what spot on the plug/color the ac wire is in my climate control for a dc teg. If anybody know that could tell me or post up a diagram that be awesome.
The "A/C wire", [A/C request lead] is blue/red at the A/C switch, it is a " high-current" ground output, the ground input to the switch is green, the ground is supplied by the blower switch, [must be on].
The A/C switch output, [blue/red] runs and connects to/through the A/C thermostat.
The A/C thermostat has 3 leads, the above blue/red, [ground input] a black/yellow, [power, 12V+] and the yellow/white, [ground output].
The A/C thermostat output, [yellow/white] runs and connects to the A/C pressure switch.
It goes on and on. 94
