Using Gsr head Built for LSVtec on GSR Block
Old Jul 18, 2012 | 11:40 AM
WSA's Avatar
WSA
Default Using Gsr head Built for LSVtec on GSR Block
A while Back I picked up a GSR head that someone was going to use for LSVtec. I got it for close to nothing as he really needed the money. I know that it has full ferrea vavle train 0.5mm oversized with a 3 or 5 angle valve job. It also has victor x manifold and skunk2 cam gears. Anyways, I am not at all familiar with LSvtec and I am wondering what could have been done to this head for the lsv setup? Can I use it on my GSR block still? I do plan to have a machine shop inspect it all and resurface/replace as needed. Also is there a way to tell what ferrea valve train it has? Thanks in advanced guys.
Old Jul 18, 2012 | 02:01 PM
MonkeyMagic's Avatar
Default Re: Using Gsr head Built for LSVtec on GSR Block
better off asking in the all motor forum on here. good luck though
Old Jul 18, 2012 | 02:13 PM
SPOOLINmatt's Avatar
sounds like you need a block with aftermarket pistons for the over size valves. Not a big deal otherwise, except make sure to remove the oil port plug.
Old Jul 18, 2012 | 04:34 PM
civickiller's Avatar
Old Jul 19, 2012 | 01:06 PM
WSA's Avatar
WSA
ok thats what I was looking for. This is on the bottom of the head correct?
Old Jul 19, 2012 | 07:04 PM
scheffee's Avatar
or you can leave the plug in and run an oil feed line as if it were an ls vtec
ogmudbone
Mid-Atlantic (Sales)
Apr 28, 2010 10:37 PM
killerB16A
Dec 30, 2009 06:00 PM
ferio_boy
Sep 6, 2008 09:02 PM
jdmeng
Dec 10, 2007 07:37 AM
