DPFI to MPFI Conversion.
a Mini-me is not going to give you much power. just swap the d16 in. their are various ones. here is a link on the mpfi conversion http://hondaswap.com/swap-articles/d...writeup-49557/ here is one on swaps for the efs http://ef-honda.com/ben/EFswapguide.html
Going to need a crx or civic si ecu and distributor and intake mani, of course injectors and resistor box, a few wires will have to be messed with. Been done a million times and there are lots of write-ups. Getting rid of the dpfi is the first ad best step you can take with your Sohc.
Not looking to race this motor just need a lil bit more hp. The swap would be a GSR but for now i wanna pump the 1.5 sohc as good as i can cause itll be my daily motor to drive till i get another ef. Thanks for the responses. Will be looking for someone to do that swap.
Yes D16a6 head will bolt onto a D15b2 block. There are certain things you need to do to make timing right because of different deck height. This link should tell you everything you need to know about this particular mini-me.
http://www.d-series.org/forums/engin...-cam-post.html
If you need a new, and I mean brand new conversion harness Lmk. I make these all the time. No used, cut up or soldered together wires. All brand new
Sample video of a new DPFI to obd1 vtec conversion
http://www.youtube.com/watch?v=puPiw...e_gdata_player
Honestly, I wouldn't bother with swapping non Vtec heads. If you were to swap heads I would do a Z6 head on the a.5 block. Bolts right up and nets you a zippier little Vtec Engine.
You would need the following
Z6 head
Z6 Dizzy ( with wires )
Z6 ECU
OBD0-OBD1 Jumper harness
4 wire Oxygen Sensor
You would obviously have to do the DPFI to MPFI conversion 1st but that's the easy part.
What you are doing converting from 2 injectors to 4. Also adding Cam Angle sensor ( 2 wires ( blue/green & Blue/ yellow ) and relocating the Crank sensor from c1,c1 to b10, B12.
I can get it done if you are close enough to me. We discuss cost and what not. Most important thing here is to buy all the correct parts. I did a swap for this one guy here and he didnt have the right Dizzy nor the right Intake Manifold. Makes the swap take longer.
Good luck.
Z6 head
Z6 ECU
Good luck.
Z6 head
Z6 ECU
Good luck.
Z6 head
Z6 ECU
Good luck.
If you plan on boosting vtec hardly matters. If you want to stay N/A with the D15b2 but want a little more power do the A6 head,
mill it a little,
Call up delta cams,
throw on a header and good flowing exhaust along with your mpfi swap it should have alot more pep.
Keep in mind if you do put a cam in mild or wild you will need to tune, and same goes if you mill enough off of the head.
berts95ej
Jul 14, 2007 07:41 PM
Jesterian
Jul 11, 2005 08:38 AM
depoch
11
Feb 13, 2004 05:21 PM
