Two Questions regarding ZC axles and clutch...
Old Oct 15, 2002 | 10:58 AM
X's Avatar
X
Default Two Questions regarding ZC axles and clutch...
Hi everyone, its been a long time since I've been here, so I hope you guys can help me out...
1st Question.
I'm running a 90-si-hb with a zc motor and zc transmission. As of right now I'm using a 1989 integra axles. The problem is, that I think it might be a little short because if I turn it hard I would snap them.
Which axles am I suppose to use:
88-89 integra axles (they work without any modification to the hub but feels a bit short)
or
90-93 integra axles (supposively they are longer but do I need to change the hubs so the teeth of the axles will fit?)
2nd Question.
When I purchase a new clutch, since I'm running a zc tranny, do I buy one made for civic or integra trannies?
I'll be working on the car this weekend, so your help is greatly appreciated...
Old Oct 15, 2002 | 11:00 AM
EP3_05's Avatar
Default Re: Two Questions regarding ZC axles and clutch... (X)
I have heard to run the 90-93 integra axles and intermediate shaft. And the axles will fit into the hubs without having to change them. For the clutch buy a civic clutch based on what year your transmission is.
Old Oct 15, 2002 | 11:07 AM
X's Avatar
X
Default Re: Two Questions regarding ZC axles and clutch... (91civic)
91civic,
Thank you for your prompt reply...
One question...I'm currently using the intermediate shaft that came with my ZC tranny, are they compatible with the 90-93 axles?
Thanks again...
Old Oct 15, 2002 | 11:17 AM
keithv's Avatar
use the ZC intermediate shaft and the 90-93 teg axles.
Old Oct 15, 2002 | 01:34 PM
jlicrx's Avatar
Default Re: Two Questions regarding ZC axles and clutch... (breaka_1_9)
90-93 integra on left side - 85 accord sei (fuel injected) on right side - it is 1/2" longer and doesn't tend to come apart - everything else on it is the same as integra (cv's, etc.)
must be 5 speed
[Modified by jlicrx, 10:40 PM 10/15/2002]
Old Oct 15, 2002 | 05:07 PM
ZC'n'it's Avatar
I had the same same problem about 5 months ago,I did some home work and found out that you can use righthand 90-91 civic axles on both sides with 90-93 integra inner joints.I know this works because thats what I've got on my civic now.
crxguy406
Jun 29, 2013 09:50 PM
shivic
Aug 11, 2004 06:12 PM
dohcnotec
Jun 26, 2004 11:47 PM
JDMVTEC
Nov 2, 2003 05:57 PM
beyond-redline
Jan 28, 2003 06:41 PM
