Defi BF Gauges*Oil Press*Oil Temp*Water Temp*11K Tacho*Control Unit*
Old Jul 16, 2012 | 02:53 PM
Crank's Avatar
Default Defi BF Gauges*Oil Press*Oil Temp*Water Temp*11K Tacho*Control Unit*
Selling as a complete set****
Semi complete.. missing sensors for the oil temp, water temp and oil pressure. you can buy the sensors new for about $50 a piece.
Everything's in full working order. No damages or whatsoever. All plugs and wires are also original and not hacked up.
Whats included:
Defi BF 60mm Oil Pressure w/mounting cup *white
Defi BF 60mm Oil Temperature w/mounting cup *white
Defi BF 60mm Water Temperature w/mounting cup *white
Defi Tachometer 115mm w/mounting cup *green (fits perfectly inside a EG/EK cluster)
Defi Control Unit
$600 for the entire setup listed above. (each meter alone already goes for $300 each!)
the faces on the gauges are clean with no scratches, its just dirty.
Crank's Avatar
located in san francisco
Old Jul 18, 2012 | 08:17 AM
EVIL EF9 RHD's Avatar
Default Re: Defi BF Gauges*Oil Press*Oil Temp*Water Temp*11K Tacho*Control Unit*
bump
Universal Magnetic
Northwest (Sales)
Jan 26, 2008 08:24 AM
mr abstract
Jan 23, 2007 02:00 PM
_gurusan_
Nov 16, 2005 08:26 PM
type Gendy
Aug 31, 2005 07:11 AM
