first time engine swap on my crx si
Old Jul 16, 2012 | 11:27 AM
ox_22's Avatar
Default first time engine swap on my crx si
Hi there honda-tech members this will be my first time doing a engine swap so i was wondering which shift linkage, header, engine mount i will have to use when i do my B-series swap into my crx?
Old Jul 16, 2012 | 10:07 PM
Exelbaradin's Avatar
Default Re: first time engine swap on my crx si
88-91 Honda Civic/ CRX EF B-Series Swap (Cable Type)
What You Will Need:
Innovative Mounts Civic/ CRX EF B-Series Conversion Mount Kit Part # 19150 or B19150
B16A or B18A M/T Intermediate Shaft
Innovative Mounts or OEM B-Series Cable Type Swap Axles (pair)
B16A/ B18A Motor and B-Series Cable Transmission
Dual-to-Multi Point Conversion Wiring Harness (DX/ LX only)
B-Series OBD0 ECU (pr3/ pwo B16A pr4 B18A) or Other Appropriately Programmed ECU
Custom Length B-Series EF Shift Linkage
90-93 Integra Throttle Cable or Innovative Mounts Throttle Cable Bracket Part# 59510
Cable-Type B-Series Vehicle Speed Sensor (VSS)
Rear Engine Mount Bracket from 90-93 Integra M/T
90-01 Integra Lower Radiator Hose
90-93 Integra LS/ RS/ GS Upper Radiator Hose (B18A) or 92-93 Integra GSR Upper Radiator Hose (B16A)
Innovative Mounts B-Series A/C Bracket Adapter (If Applicable)
Recommended Smaller Alternator Belt
Modified Front Crossmember or Recommended Innovative Mounts Crossmember or Competition Bar
88-91 Civic / CRX SI or 5-speed DX OEM Front Spindles/ Hubs (HF/ DX 4-speed chassis only)
Tools:
Metric Socket set 8mm – 19mm
32mm Socket
3/8” Short, Medium & Long Extension
10mm, 12mm, 14mm, 17mm, 19mm & 22mm Open-end Wrenches
Die Grinder with Cut-off Wheel & Sanding Disk
Hammer
Pry-bar, Roll-Pin Punch Set
Needle-Nose Pliers
Hose-Clamp Pliers
weaksoN!
Feb 20, 2017 04:47 PM
hatched91zc
13
Aug 31, 2009 07:29 PM
upallnight
Jun 2, 2007 10:24 PM
1quickcrx
Northwest (Sales)
Jun 10, 2005 11:04 AM
