Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr trans case broke need info
Old Jul 16, 2012 | 09:56 AM
Si-rdc2's Avatar
Default gsr trans case broke need info
I just got a gsr trans and the case is broke where you bolt the t bracket at need to the speedo would it be safe to still run it with 2 bolts in it or switch the case since I have a spare ls case
Old Jul 16, 2012 | 02:37 PM
Aquafina's Avatar
Default Re: gsr trans case broke need info
Might be able to get by, I wouldn't though. Switch the case. Be sure to shim the mainshaft and diff.
Old Jul 16, 2012 | 03:14 PM
Si-rdc2's Avatar
Do I have to change the bearing and how do you shim it I have the case off a trans but never got to rebuild or change anything
Old Jul 16, 2012 | 11:40 PM
Aquafina's Avatar
You will need a Helms manual and a few specialty tools from Honda (for the mainshaft). What style diff bearings does the GSR have?
Old Jul 17, 2012 | 08:01 AM
Si-rdc2's Avatar
I have not opened it yet but I pulled the axle seals looks like its not the same as the ls
Old Jul 19, 2012 | 06:34 AM
OH_1fstgsr's Avatar
Here are the numbers from http://www.hondapartsunlimited.com/
Another possible option is a used trans.
Old Jul 20, 2012 | 07:57 PM
Aquafina's Avatar
The cases are the same.
I would have the internals swapped over by someone that has experience doing so and has the proper tools. Much better route knowing what you actually have than taking a chance on a used trans.
kodylive
Sep 24, 2012 04:37 PM
JDMB20TDA
Sep 28, 2008 09:19 AM
DA3
Aug 30, 2008 08:36 PM
bball
Feb 14, 2008 11:32 PM
