Where to buy replacement D4 Light bulb?
I'm new to the forum and I didn't see this topic under Accords. I have a bad D4 light on my dash. I swapped it with the 1 light, since that ones practically brand new. I can't find a replacement at Autozone or O'Reilly's (what I have for parts in my town). Does anyone have the part number or a URL to a place I can buy about 7 of these bulbs on the net? I will replace all 7 if they're not too expensive.
Thanks.
Thanks.
I *think* its one of these three...
78181-SF1-612 019 008 BULB & SOCKET ASSY. (14V 80MA)(BASE:BLACK) (NS) 4.82 3.37
78182-SM4-003 020 004 SOCKET ASSY., BULB (14V-100MA)(BASE:BROWN) 2.87 2.01
78184-SM4-003 021 006 SOCKET ASSY., BULB (14V-60MA) (BASE:GRAY) 5.47 3.83
Thanks Mad Mike, for cluing me into the "combination meter" phrase. I found that when I Googled your part number. That terminology was what I needed for my Google-Fu to come up with the correct part number. This is for a 2001, so it looks like 78182-S84-A02 socket assy., bulb (14v 1.4w) for $5.17 each is my bulb. I couldn't have found it without your help.
I did to a temporary fix in the mean time. I had a Radio Shack bulb left over from where I fixed the passenger airbag light on my F-150. I took the old burnt out bulb out of the nearly microscopic black plastic holder and threaded the slightly smaller bulb into the socket and wrapped the legs around the little ears like the old bulb. (Sounds kinky when I say it that way.) Then I plugged it into the 1 position. It works. Just a little dimmer than the factory.
Ventolin
Jun 21, 2006 06:41 AM
tr0n9h
14
Sep 25, 2005 07:39 PM
