WTB: 92-95 Civic EG EX/Si Wiring Harness
So I am swapping a D16Y8 into my 93 Civic DX. It's currently automatic but I have everything to swap it to a manual. To make the engine swap a bit more easier I am planning on using the EX/Si harness. Let me know how much you want for it.
how much are you willing to pay? I have one. I really don't think this will make the swap that much easier though. You will still need to run the vtec wires from the ECU to the shock tower.
i do not believe so.
http://technet.ff-squad.com/hybrid.92-95.obd2.htm
using my EX/Si harness will save you about 3' of wire and 5 minutes of time. if that.
Do note that if you are dropping an OBD2 VTEC engine into a non-VTEC OBD1 vehicle , you will have to wire in VTEC, the knock sensor, and IAB (GSR/SiR-G engines only). You will have to wire these items in the same fashion as if an OBD1 engine was in your vehicle - same ecu pinout locations.
