700whp rsx part out
all parts are pretty much new the motor and turbo kit has around 8k on them and only seen around 450whp avg on the street and made the 700+ on the dyno other than that the car has been sitting. No corners where cut on this build and i only use quality parts on this build and plenty of people can vouch for this car that seen it in person, so pleas buy with confidence. my number is 7852264100 text me any time if you have a question..thank you.
engine
k20a2-7500obo
pp head by stweart head
full ferrea valvetrain
vtec killer rockers
arp head studs
erl sleeved block 88mm
cp 9:1
manley rods (turbo tuff)
s2000 oil pump
hybrid racing timing chain tensioner
circuit hero chain guide
turbo kit 4500 obo
pt6765 .82
full race manifold twin 044 gates
custom intercooler with 3inch pipes and 24x12x4.5 core
custom 3inch down pipe (all v-band and ss)
custom 1.5inch dump tube(all v-band and ss)
-3 oil feed line
-12 oil return ss braided
fuel system 2500obo
id2000(will part separate)(and also have b-series adapters also)
fuel cage with walbro 400
aftermarket industries surge tank with dual 044
hybrid racing fuel rail
aeromotive fuel pressure reg.
will also come with all the -10 feed line and the -6 return and all the relays stwiches and harness i made for it..pretty much plug and play
miscellaneous stuff
exedy twin disk (less than 100 miles)1300
tilton clutch master 250
breather can with vented vc (type r)700 obo
mishimoto rad with fans 400
rsx guage pod with aem water temp,prosport oil press,prosport boost 400obo
aem uego with new sensor 200
tein hood dampers 120
volks sf 18x8.5 with brand new bridgestone tires on them 245/40/18 2750
koni shocks and gc with one blown front one 500obo
05-06 deck lip 200 obo
ktuned spark plug cover 100
custom 3inch exhaust vband 500
custom coated rbc ported to 74mm w/
skunk 2 74mm tb with ktubed pp tps 550obo
haport 60a mounts 300
engine
k20a2-7500obo
vtec killer rockers
arp head studs
cp 9:1
s2000 oil pump
turbo kit 4500 obo
pt6765 .82
-3 oil feed line
fuel system 2500obo
miscellaneous stuff
